dma problem in diagnostics at mio 16xe 50
attached are the test results of a diagnostics run, with the online-tool ni provides. when the error message about the "dma channels" ocurred, i clicked on "ignore" for a while, then aborted after the nth repetition.
the system is windows nt service pack 6, freshly installed after a drive crash, so all configuration was lost (if there was any). would you be so kind as to advise me on possible strategies?
thank you
(2,909 Views)
the same setup, only this time i clicked "ignore" every time the error message came up, to see what came afterwards. there were some failed tests there, too, but i can't discern whether it's the same basic bug.
i checked my setup with regard to dma: win nt has no device manager, so i looked into WINMSD.EXE, which told me that dma 5,6,7 were all allocated to NIPALK (i guess thats something related to nidaq). the measurement&automation explorer says dma 5,6,7 are alolocated to the at mio 16xe - card. so that looks alright, as the mio 16xe can't handle more than 3 dma-adresses, according to the manual.
i-o ports 0200-021F and irq 05 are allocated to nipalk too, according to both winmsd and m&a-explorer.
thank you
andré
(2,888 Views)
