edge counter not functioning in MAX
Hello wise ones!
I was hoping somebody could help me with a problem I am having detecting TTL edges on my NI-2090a that is connected to a NI-6025e. Even if I go into Measurement and Automation Explorer and run the Counter I/O test nothing is detected. I tried different counters and different ports (BNC PFI0 and other non-BNC PFI's) connected to different trigger sources but still no succes. Interestingly I also have a simple USB 6008 on which I can get these settings to work.
I used a few test VIs that I found here but none worked (which I guess is to be expected).
Is there something that I am not seeing here? Any help is welcome and if you want more information please let me know!
(3,729 Views)
Hello j.win,
Which version are you using (PCI,PXI,...) ?
Can you share a MAX Report (File >> Create MAX Report), so that I can check the installed software versions?
Thanks!
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,715 Views)
Thanks for the reply!
I attached a MAX report to this post. Also in response to your question I use a PCI system.
Thanks again!
(3,712 Views)
Hello j.win,
Normally you should be able to use the counter with this combination of drivers and hardware.
Some extra things I was wondering about:
- Have you done a self-test (without anything connected to the DAQ-card)?
- Have you done a self-calibration (without anything connected)?
- Can you still measure analog input or produce analog outputs?
Is it the first time you try this set-up or did it used to work before?
Can you show me schematic of the wiring?
Kind Regards,
(3,654 Views)
Hello J.win,
Any news for us?
Kind Regards,
(3,567 Views)
Accepted by topic author j.win
Hey!
So the strange thing is that I put the card in a different computer and then the problem was fixed 🙂
Should be exactly the same drivers so I dont see how anything could have changed.
Still for me it doesnt matter anymore so I'll change it to fixed 😉
Thanks for the help!
(3,564 Views)
