Multifunction DAQ
event counting in 6024E
I AM NEW TO USING LABVIEW. AND WANT TO USE COUNTERS IN 6024-E FOR COUNTING NO. OF STROKES IN A MACHINE USING PROXIMITY SENSOR AND SC-2345 MODULE.KINDLY LET ME KNOW THE INETRFACING HARDWARE IF ANY AND HOW TO ACESS COUNTERS IN 6024E
(2,499 Views)
Bedi,
You can connect a cable from your 6024E to the SC-2345. Within the SC-2345, you can install a FT-01 module in J19 or J20 to access the counter lines. In LabVIEW, you can find example programs to help get you started by going to Help>>Find examples. Please post again if you have specific questions about any of these components. Good luck with your application!
(2,499 Views)
