I have a subvi which used report generation toolkit vis to generate an excel file, and then release from memory. The subvi works fine when executed by itself. However the runtime version (when it is called as a subvi) does not finish. The excel file is generated from a template just fine. And Excel closes...but the subvi just does not complete and close - hangs up. I have to go back to main panel, and hit stop. Ideas?
