11-14-2006 02:34 PM
11-15-2006 02:46 AM
11-15-2006 10:02 AM
Thanks a lot for your reply, I really appreciate!
The output rang of voltage is not stringent, less than 5 volts will be ok. Eventually I will send this ouput to another power supply which will take this input, amplify it and then send to drive the heater.
The input value will be converted from the thermistor reading using LabView and generate a number out, i.e. thermistor reads 10KOhm will be converted to, let's say, 4 volts.
Jie
11-15-2006 03:22 PM
