frequency measurements uisng USB 6009
I am using LabVIEW 8.0 and USB 6009. I need help to do frequency measurements (1Hz-1MHz) This USB does not support frequency measurements as 6210, I can't use DAQ assistant.
(4,322 Views)
Yup, the 6009 doesn't support frequency measurement. You could approximate the frequency using the following KB article:
Approximate Frequency Measurement with USB-600X Simple Edge Counter
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,320 Views)
Dear Adnan,
Is there any ways to improve the frequncy measurement bit more by using USB6009 (by changing the program which is mentioned by you). I need some more accuracy. My range is 1kHz to 400kHz,
Please let me know, if there are any chances
Best Regards,
Rathan
(4,199 Views)
(4,196 Views)
