generate synchronized pulse and waveform with two AO and PCI-MIO
I am using LabVIEW 8.2 and a PCI-MIO-16E-1 card.
I want to generate a sine waveform with an amplitude 0-10V and frequency f=8000 Hz for one AO.
The second AO should be used to generate a pulse/burst with an amplitude 0-5V and also a frequency up to 8000Hz.
I attached a screenshot of the vi i built so far - but how do I connect the two generated waveforms?
I know that I am generating 2 waveforms and not a waveform and a pulse, but the difficult thing for me is right now to connect them.
Let me know when you need more information.
Benno
Message 1 of 9
(4,009 Views)
I found another solution for my problem:http://forums.ni.com/t5/LabVIEW/how-to-combine-two-analog-outputs-into-the-same-task/td-p/634260
I tried to rebuilt it (see attached file)
But I get the error 20088 and 200327
What should I change?
Benno
Message 2 of 9
(3,996 Views)
Have you tried changing your DAQmx write to n channels, n samples 1d waveform?
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 3 of 9
(3,989 Views)
Yes, I tried that, but then I get the error:
Broken Wire - connected two arrays of different dimensions
Message 4 of 9
(3,987 Views)
The output from your build array should be a 1d array of waveform. You can check this by hovering over the output wire with context help on.
If it isn't unhook all wires from the build array>>right click it>>concatinate inputs and hook it all back up.
hope this helps.
Message 5 of 9
(3,983 Views)
It is a 1D array of waveform.
One Problem was, that both 'waveform buffer generation.vi' needed a task in.
So there are 2 tasks out - can I combine them into one task out? Or should I just connect one of the task out with the DAQmx Timing.vi?
The new Error is:
Error -200524 occurred at DAQmx Write (Analog 1D Wfm NChan NSamp).vi:1
...Write cannot be performed, becauase the number of channels in the data does not match the number of channels in the task...
number of ch in task:2
number of ch in data:4
see my attached screenshot, how I wired everything...
Message 6 of 9
(3,944 Views)
Since you are using 2 Buffer Waveform vi's and you select 2 channels you are actually creating 4 waveforms. Here is an example that will do what I think you want.
Hope this helps.
Message 7 of 9
(3,931 Views)
yes, it helps!
But I need to change the basic function generator with a pulse generator or something like a waveform generator with a burst mode.
I can't find something like that in LabVIEW... Do you know which vi would be the best to work with?
BTW: Thanks a lot for your help!!
Message 8 of 9
(3,922 Views)
Since I don't know the requirements of your 'burst'/'pulse' or the capabilities of your card (I don't have one) it's hard for me to suggest something specific. I would look into functions>>signal processing>>signal generation and see if something there would suit your needs. Those vi's will create an array of doubles that you would wire into the build waveform primitive, designating  the dt and to as needed. If it was me I'd create an experimental vi without using the daq to get my waveform to what I needed. A while loop and waveform chart.
If you have a formula that describes your pulse you might be able to use the formula waveform vi.
Hope this helps.
Message 9 of 9
(3,911 Views)
