generating a TTL pulse continuously with specified frequency
have an SCB-68 E series, and it has digital outputs (which is where I think is where you generate TTL pulses).
I tried signal express to generate a TTL pulse but I'm not sure if I need a "line" or "port", it is being used to send a TTL pulse to a device as a trigger.
So I just chose, port and set it to continuous but it says I need a sample reference clock BEFORE as an input.
All I am asking for is for
generate a TTL pulse at a specific frequency continuously until I ask for it to stop.
I am also using LabVIEW but can anyone help?
(4,742 Views)
spark3:
The SCB-68 is just a connector block. We need to know what model DAQ card is installed in your computer first to determine its capabilities.
Do you need to send just one pulse or a train of them at a given frequency?
-AK2DM
(4,723 Views)
oh ..
the DAQ card used is a PCI-6229
i need a continuous TTL pulse at a frequency that i can variate
btw i found this example in the NI tutorial but i don't think this is a TTL pulse?
thx, i won't be able to test anything for a week (otherwise i would have done a trial and error and keep trying almost random stuff). but i would like to get a solid head start.
thanks for the help in advance!
Message Edited by spark3 on 10-07-2009 01:58 PM
(4,713 Views)
LabVIEW has a lot of ready to run examples that ship with it.
Under LabVIEW- Help/FindExamples/HardwareInputAndOutput/DAQmx/GenerateDigitalPulses. It will even show if your hardware supports the program.
Have Fun!
-AK2DM
(4,704 Views)
i've been looking at these (but not able to test)
but are they TTL pulses?
i thought it wouldn't be CO Pulse Freq
but digital output.
but i will tell you how everything goes in about a week and thanks in advance!
(4,701 Views)
Yes, the digital I/O and counter/timers are TTL logic levels, specs here: https://www.ni.com/en-us/support/model.pci-6229.html -AK2DM
(4,694 Views)
