get waveform from TDS2012
      the attachment is an example whose function is to acquire the waveform from an oscilloscope  from a reference book. Now I'm wondering whether the waveform displayed in the waveform graph is just the waveform the oscilloscope acquires. My oscilloscope is TDS2012. I connect the oscilloscoe probe to the channel 1 input connctor.Attach the probe tip and ground lead to the PROBE COMP connectors.The  PROBE COMP signal is a square wave with a frequency of 1KHz and a peak voltage of 5V. If I choose channel 1 as the trig source, and let the programme run for 1000 times,it will take more than 1minute to complete this task. I just want to know whether the  waveforms  refreshed in the waveform graph are generated by the source during the  1 second since the programme starts.  Thanks!
Message 1 of 1
(2,965 Views)
