12-20-2006 03:25 AM
12-20-2006
05:41 AM
- last edited on
07-15-2025
02:10 PM
by
Content Cleaner
You can download the latest and compatible version of device drivers for this DAQ card from here
Depending on your OS, choose the relevant Device Drivers
12-20-2006 11:08 PM
hi devchander,
thanks for the valuable info. I'm downloading the driver now and will try out if it can resolve my analog input problem.
however, i got bigger problem where my current digital input module model is AT-DIO-32HS is having ISA connector which i dont have it on my new PC.. (new PC doest have ISA slot). Could anybody advice me the solution?? preferably without any expenditure????
prompt support is highly appreciated
max
12-21-2006 03:27 AM
12-21-2006 04:29 AM
thanks again dev,
i have struggle to get the PCI / ISA adapter but yet to find them in the market. could you advice any manufacturer whom supply this device? btw, i have also search for the driver (AT-DIO-32HS) but unable to get it from the NI website. pls advice me the URL???
thanks again for the support.
Max
12-21-2006
04:51 AM
- last edited on
07-15-2025
02:11 PM
by
Content Cleaner
01-08-2007 03:16 AM
Hi Dev,
i've been trying to download the tdaq741.zip file several times but it fail in the midst of the download every times. i dont know how to complete the download. is there any other way to get the file? i'm getting tired with this problem. please advice the solution???
theres only two drivers required.
1. PCI-6023e
2. AT-DIO-32HS
Max
01-09-2007 09:01 AM
01-10-2007 03:37 AM
Thanks for the support. I've managed to get the modules detected. I will need to configure my system to make it work.
Max
