Multifunction DAQ
how can I display time of recorded data in a file using labview?
(2,969 Views)
Accepted by topic author Monireh
Hi Monireh,
I think we'll need a little more info as to how you're capturing the data, what data you're capturing, etc.
If you're capturing a waveform, one way is to extract the waveform time data which includes the t0 and the dt values so you can figure out the timestamp of a specific data point as in the image below.
Jeff | LabVIEW Software Engineer
(2,943 Views)
