how can I measure the thermo couple using PCI-6024E DAQ card
How to use PCI-6024E to measure thermo couple
(3,433 Views)
Greetings,
You can find more information on the following two websites:
http://zone.ni.com/devzone/conceptd.nsf/webmain/806355D26B7378B1862567EE0003A842?opendocument#2
http://zone.ni.com/devzone/conceptd.nsf/webmain/0C3E2A48D9870E3586256D8F006CE0A9
In general, the PCI-6024e by itself is not ideal for measuring temperature. You need to add some signal conditioning to properly amplify the signal and attain the best resolution. The other option is to use a 16 bit DAQ board.
AnujD.
(3,433 Views)
Can the PCI-6024e DAQ card be used to measure an LVDT and a load cell input or would signal conditioning be required. If signal conditioning is required, what kind of amplifier would u recommend to drive a lvdt and load cell signal.
Thanks in advance
(3,411 Views)
Jeevan,
You can use the SCXI-1540 to measure LVDT signals. Additionally, you can measure load cells with the SCXI-1520.
AnujD.
(3,399 Views)
