how can i know if DAQmx works well
I have a program which can be runned very well and can control the instruments under DAQmx (PCI 6259) as well. Recently i bought a new DAQmx (PCI 6259) and installed it on a new computer. When using  the same program to control the same instruments, i found that the program can not work well and control the instrument. I guess the problems are from the DAQmx card. So i would like to know how can i know if DAQmx cark is good or bad.
(3,194 Views)
Are you questioning DAQmx or the hardware? Please try to differentiate between a driver and the hardware itself. Saying the 'program can not work well' is not at all descriptive. Explain exactly the problems you are having. Check the version of DAQmx and make sure it is compatible with the new pc. Run the self-tests in MAX.
(3,188 Views)
Self-test is ok.
(3,183 Views)
i use our program to control the tapping of instruments. All the hardwares are same. i just bought a new DAQmx card and a labview 2012. The runing of program has no error. Just the program can not control the instruments. i test a lot of parts where perhaps there are problems. But i can not resolve it. Thanks.
(3,181 Views)
If you are having problems yet, why would you mark the thread as solved? Unless you really meant to say 'I can resolve it' in which case the thread is closed.
It it is unsolved, change that by clicking on the options button. Then explain what instruments you are trying to control and how. How exactly are you using the DAQ card? Can you post your code?
(3,175 Views)
