how can i use my BBC to program my E-series DAQ
Can some1 tell me how to use my Borland Builder C/C++ to program my E-Series Daq. Links are accepted greatfully. Thanks to the crew!
(2,692 Views)
Rupinho,
Here is a link to a KnowledgeBase entry about installing Borland support from NI-DAQ: http://digital.ni.com/public.nsf/websearch/E61ED056FB8D15D986256931006B2191?OpenDocument.
Once you have installed the support files and examples, you should be able to open and run the examples and see the method of programming used. There are also a few other examples online. Just go the Example Code Library in the Developer Zone and search for Borland.
Good luck with your application.
(2,692 Views)
"Sarah,
Thank's very much! But i'm still a bit confused.
I'll tell u here i'am: Borland Builder C++ rev 4.0 Enterprise edition installed on my host, NIDAQ 7.0 installed on my host (the same). Now when I open a new project in BBC++ which files do i have to link;
headers files(xxx.h)and which lib files??
how do i get all the functions name and parameter to pass, in the lib file??
Thank's for your pacient.
(2,692 Views)
Currently, NI-DAQ 7.0 does not support the Borland compiler. Use NI-DAQ 6.9.3 or earlier. Also, when you are installing, make sure ot select Borland as your compiler and opening examples should go much smoother.
(2,692 Views)
