Multifunction DAQ
how do I connect thermocouples to scxi-1122
I need to connect two thermocouples to an scxi-1122 module. How do I do this? It will be running (hopefully) under labview.
(2,711 Views)
Mike,
Below are links to two very good resources. The first is a tutorial concerning the use of thermocouples with an SCXI-1122 and the second is the SCXI-1122 User Manual:
How to Use Thermocouples with an SCXI-1122 Module
Good luck with your application.
Spencer S.
(2,711 Views)
