Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
how do I connect thermocouples to scxi-1122
MichaelMina
Member
03-05-2003
02:32 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I need to connect two thermocouples to an scxi-1122 module. How do I do this? It will be running (hopefully) under labview.
0
Kudos
Message
1
of 2
(2,701 Views)
Reply
Re: how do I connect thermocouples to scxi-1122
Spencer S.
Active Participant
03-06-2003
02:28 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Mike,
Below are links to two very good resources. The first is a tutorial concerning the use of thermocouples with an SCXI-1122 and the second is the SCXI-1122 User Manual:
How to Use Thermocouples with an SCXI-1122 Module
Good luck with your application.
Spencer S.
0
Kudos
Message
2
of 2
(2,701 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
