how to add the external source Vcc at optocoupler ? and connect it to the USB DAQ
I want to connet My daq to Optocupler for count RPM , i use PFI 0 anda Groud and connet to Vout and Negatif Optocoupler. But Optocupler need Vcc and my daq doesn't have sourcE, How do I get source ?And how wiring it?
please Help me..
(4,932 Views)
Andriawan,
I'm not exactly sure what kind of device you're trying to connect; are you trying to do analog input or analog output?
Kirk L. | Applications Engineer | National Instruments
(4,901 Views)
i want to connect digital input...
(4,897 Views)
According to the manual the MyDAQ has a +5V source pin. (And even if not , you migth abuse a digital output as a source (with a max current according to the manual/spec)  😉 )
You didn't mention the type of OC you want to use. Assuming a standard one:
Add a 10k pull up resistor from +5 to the coupler open collector out  (and your digital in)  and then from the coupler emitter out  to DGND.
If you are not shure, post a link to the datasheet of the OC.
Greetings from Germany
Henrik
LV since v3.1
(4,868 Views)
thank you so much mister.... Smiley Very Happy
greeting from java Indonesia..
(4,819 Views)
