how to build an array for opened TDMS file
Hello
From the NI examples TDMS - Express write data (time domain).vi, I can build a TDMS file with 2 channels(sine and square waveforms) of data, which is stored as test.tdms.
By using Express read data (time domain).vi, the 2 channels of waveform data is read out. How to build an array afterwards? How to split the 2 channels of data into 2 1-D arrays and manipulate the data using array functions?
For example,
I want to take 100 sample starting from index100 from channel 0 and average them. I want to take 50 samples starting from index 50 from channel 1 and double each element.
Thank you for your help.
Bing@NCL
(3,971 Views)
It looks like the entire file is being read. You can use the convert from dynamic data to get a 1D waveform, 2D DBL, etc. The split signal function can be used on the dynamic data but if you are going to convert to some sort of array, just use the index array function.
Your questions are pretty basic. Have you taken the LabVIEW tutorial?
(3,969 Views)
Accepted by NCLbingji
Hey Bing,
You can perform operations on different channels in the 2D array using the index array function. This will allow you to choose the channel to operate on then you can perform the operation inside a loop to act on each element. In the snippet included I have used a shift register to find the cumulative total of the values in channel 0 then divided by the number of samples checked.
I would recommend reading some LabVIEW tutorials and KnowledgeBases on topics that are relative to yours. These might help alot.
Hope my suggestions help,
Chris
National Instruments - Tech Support
(3,950 Views)
Thank you. I will go through the tutorials
(3,912 Views)
