04-23-2013 02:42 AM
It works perfect with your setting JB.
Although, I am using an AI, because I have all the de DI occupied.
Ah, and the relay is driven by an external device, I just wanted to check how is it set.
Thank you very much.
04-23-2013 07:38 AM
An AI to check if a contact is ON or OFF is a quite "expensive" solution but obviously, if there is no remaining DI...
