Sumits,
Regarding your concerns:
1)when the loop is not yet over with Scan_Start(), is it possible for me to retrieve the voltage values..(?)
Scan_start is an asynchronous function that will block access to the device and you will not be able to read the data before that function ends. If you are referring to the acquisition loop, you may want to check the DAQ_Monitor function (refer to the NI-DAQ Function Reference) to read smaller chunks of data than a half buffer at a time.
2) in what order is the voltage in the buffer passed back to the program. what is the sequence (?)
It's returned in a [chan1] [chan2] [chan3]..[chan1] [chan2] [chan3] kind of sequence. You can use the SCAN_Demux function to de-interleave the acquired samples.
I hope this hel
ps,
Alejandro Asenjo
