how to interface NI USB 6210 with AC DRIVE (YASKAWA j1000)
i want to control speed of 3 phase ac motor through PC. i am using labview software for programming. As an interface i am using NI USB 6210 DAQ.
Problem is i am unable to understand interfacing NI USB with AC DRIVE .
help me .
(3,823 Views)
Accepted by kaurtej
The short answer is you don't.
A quick look on the Yaskawa site says:
  • Modbus 232/422/485 Communications
How were you planning to use the 6210?  It only has is 4 digital outputs.  I would call Yaskawa support and ask because it looks like some of their equipment has LabVIEW drivers.
I also found this:
http://forums.ni.com/t5/LabVIEW/how-can-i-control-a-Yaskawa-V1000-variable-frequency-drive-with/td-p...
(3,800 Views)
thanku sir
i too had heard that yaskawa is providing with labview drivers for ac drivers but i hadnt got anything related to j1000 yaskawa labview drivers. if you have any thing to share regarding this then please provide me with this help .
(3,781 Views)
