how to make a program to filter (lowpass) the waveform from my initial waveform
hye,
i have got the EMG data to display at waveform graph. what i want to do now is from that waveform, how to make a program to filter it by using lowpass filter. from the new value of waveform i want it able display to txt format. i have already doing selected the Express Filter function as well as the functions on the Signal Processing>Filters palette, i do not have any idea how and where to connect the my own data to filter it after i has select Read From Measurement File. i have try many times, but i got no idea. can you give me the tip or program like i want. thanks
Message 1 of 15
(6,061 Views)
duplicate post
Do not start a new thread for a question you have already asked - and gotten an answer for. If you are still confused, post your code and file and do that to the original thread you started.
Message 2 of 15
(6,054 Views)
morning, hye dennis, i am sory what i am done before.
here, i attached the emg data i have get and the program like yours said to do it.  actually i already get do to view waveform from my EMG data signal, after that, i want to filter the waveform signal i get by usinglowpass filter and also want view the new waveform after filter it. and then, i want the new dataenter in txt format. ihope you can help me. thanks
Message 3 of 15
(6,041 Views)
In the 'express filters', you show how a filter is connected to the Read From Measurement File and then displayed in a graph so your question does not make any sense to me?
p.s. Attaching images of code is not the best idea unless you attach a snippet (LabVIEW 2009). No one can debug an image and Express VIs hide way too much code to be able to diagnose any problems.
Message 4 of 15
(6,026 Views)
Why don't you just simply wire your signal to filter express vi, and wire its output to write to measurement file vi?
I don't see any difficulty doing so.
Message 5 of 15
(6,020 Views)
hye dennis,
actually i already upload the program,but during i click send, the error about not suitble format appeared. so, i think why format .vi can not sen in this email also file in .lvm. actually i want really to show you what im done.
Message 6 of 15
(6,008 Views)
How are you trying to attach the files. Are you not using the 'Add Attachments' option? It's right below the message body.
Message 7 of 15
(6,003 Views)
yes..im do it like you said. but i do not know whye the error appeared..i will try again.
Message 8 of 15
(5,998 Views)
this is what i have done. but i still do not know how to attach it. can you help me.
Message 9 of 15
(5,886 Views)
Can you attach an error screenshot?
Message 10 of 15
(5,878 Views)
