how to make a program to filter (lowpass) the waveform from my initial waveform
I removed the read file function since you did not attach a file to be read and then ran the VI. No errors occurred with the default values of the controls. Everything seems to be working just fine.
Message 11 of 15
(1,508 Views)
here i attached the error appeared.
Message 12 of 15
(1,507 Views)
Just make sure that you configure express vi to match with condition mentioned in error screenshot, and error will not occur again.
Message 13 of 15
(1,490 Views)
hthis is the problem error.
Message 14 of 15
(1,481 Views)
Posting the error message again does not do any good. As already mentioned, the VI that you posted does not have any errors when run. You must be changing something before you run it and not saving it. What is the actual frequency you set when you run it and what do you set the filter to. It sounds like you have set some illegal filter parameters.
Message 15 of 15
(1,471 Views)
