how to return moving string data, line, and numeric on a waveform chart??
dear all..
I have a problem to return a moving string data, line, and numeric on a waveform chart.
I tried to return a data each time i interupt by using a controll with event case and i want the current data is holding on till i release the control button, next the data will empty but actually keep moving relative to horizontal scale, and return data again when i interupt it. I want to return those three datas on a waveform chart.
I hope all of you can help me to fix my problem.
thanks in advance..
Message 1 of 8
(3,668 Views)
The description of your problem is a little confusing.
couold you attach the code of what you are trying to achieve?? it would help us answer better
It looks like a LabVIEW related query.
I would advise that, in future, post such queries on LabVIEW discussions board for a quicker reply
Message 2 of 8
(3,666 Views)
okay.. i hope this will explain better.
i have a waveform chart returns plot of datas from my acquisition card.
aside from plotting those datas, i need that chart also plot other datas like string data, and numeric data.
can u help me to do that??
i think it isn't something to show in a code coz my code is actually can be subtituted with a plot of a sinus on a waveform chart.
the problem is, can i plot other types of data like numeric or string on a chart??
thats my question.  hope u can help me do this.
thanks.
Andre.
Message 3 of 8
(3,661 Views)
Yes the Numeric data can be plotted on a chart. Look at the chart example vi's, that are shipped with LabVIEW
string data?? could you please explain that a bit more?? do you mean plot a text on a chart??
Message 4 of 8
(3,656 Views)
dear dev.. i'm sorry if i cannot explain it clearly.
yes, i actually want to plot text on a chart, and the numeric data i said before is a number, not a point.
please help me if u know how to do that.
thanks dev.
Andre.
Message 5 of 8
(3,655 Views)
Well, you cannot feed strings and numbers as display parameters to  a chart
If you could explain what exactly is the type of string display that you want to do, we could suggest some tricks to make a string 'apparently/virtually' appear on your chart's plot area
Message 6 of 8
(3,651 Views)
Message 7 of 8
(3,651 Views)
dear dev,
i want to display or plot text data just like a moving letter same with the moving point from signal generated by DAQ.
but it is not continuous. for example: if i push a button that equivalent with "A" then "AAAAAAA.........." will be displayed on the chart till i release the button. And sometimes, there will be three text datas are stacked, displayed simultanously. I still not found how to do this...
if u can get me a trick, i would appreciate it.
regards.
Message 8 of 8
(3,647 Views)
