how to select DAQ card for two encoder input and one PWM output for DC motor control.
how to select DAQ card for two encoder input and one PWM output for DC motor control.Which card is of low cost and meeting above requirment
(2,800 Views)
For an encoder measurement, you need a counter and for pwm output, you need a digital line. In your case, that would mean a minimum two counters and one digital line. Have a look at the following webpage to find the right data acquisition device:
http://www.ni.com/dataacquisition/
You will need to decide on the form factor (PCI, USB etc.) and other things that will help you reach a decision. I would also recommend contacting your local NI office, to find a sales engineer to help you make that decision.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,795 Views)
