how to set iepe property in labview signalexpress
Hi, I have Labview 8.5 here connected to a USB-9234. We are trying to use accelerometer which need to be configured as IEPE, I tried as one post in this forum: http://forums.ni.com/ni/board/message?board.id=100&message.id=1976&query.id=143505#M1976
but I can't find it in the Labview signalexpress neither when I browsed as the address in that post.
Here is my searching addess: C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\DAQmx,is that right?
(3,726 Views)
Accepted by lester14
Hi Lester14,
          To configure your accelerometer as IEPE, you'll want to do this from within LabVIEW rather than trying to navigate to it through C:\Program Files (you'll need a property node which cannot be easily navigated to- the other forum post where this was mentioned is talking about using DAQmxBase which uses VIs to set this property rather than a property node).  I think all the information you'll need is found in THIS KB.  Let me know if you need more help!
(3,710 Views)
Great! I didn't realise that Iex source was for the IEPE option. Thanks.
(3,700 Views)
