how to set on /off filter of pci 6281
I want to know ,how to configure the filter of pci 6281, in the specification sheet it is mentioned that small signal bandwidth of card is 40k for fiter on and 750 k for  filter off.
(3,075 Views)
I assume you are using LabVIEW
Look at this Link,
The "2. Minimize Noise with Onboard Lowpass Filter" section illustrates how to programatically enable/disable the on board filter in this device, using a DAQmx Channel property Node
(3,063 Views)
