Cont Acq&Graph voltage to file (binary)
I use NI DAQCard-6024E(PCMCIA). When using Cont Acq&Graph Voltage - To File(Binary). vi and then read data file using Graph Acquired Binary Data.vi , I get raising signal instead of constant. Maybe I get sum of signals (for example, previous loop data  plus current loop data)?
Thanks in advance,
tamchik
(3,670 Views)
Not likely.
The reason would be your signal connection mismatch
In which mode have you connected the signal??? Differential?? RSE, NRSE??
And in which mode are you measuring in your program??
Check on this aspect
regards,
Dev
(3,665 Views)
Thanks for reply.
I`ve  connected signals in RSE mode. When I`m using Test Panel in MAX, it all right.
Where I can configure measuring mode in this vi?
(3,645 Views)
Look  at attached pic
Hope this helps
Dev
(3,604 Views)
