how to test a Mother Board step by step with Black screen and no Beep
Can you convert the schematic Protel files to PDF or Postscript or ??
I cannot read the Protel files and I don't have a viewer.
Message 11 of 20
(1,894 Views)
Hi KC,
here itis in PDF
thanks
     Rick
Message 12 of 20
(1,871 Views)
Ohh beautiful  Smiley Tongue   one big sheet with all components. To bad I don't have a A0 printer  Smiley Sad
Do you also have a partlist. They are not mentioned in the schematic.
Do you have more descriptions then your first post ? or anything else....
Message 13 of 20
(1,865 Views)
Smiley Very Happy Sorry normaly I work with Protell there you click and You know itSmiley Wink
You think just the IC'S should be Ok?
1) U1 = Winbond, W29C020C
2) U2= ICS,  ICS9169M
3) U3= Geode, GX1 200B-85 1,8
4) U4= Maxim,  MAX211EAI
5) U5, U6= Texas ins., LV573
6)U7= Geode CS5530A
7)U8 = Pulse PE-68515L
8)U9= National PC97317ICL/VUL
9)U10= National DP83815DVNG
10) U11 ST 93C46
11) U12,U13,U17 = LT, LTC1149 (3,3V 5V, 1,8V)
12)U14, U15, U18= Fairchild, FDS4559
13)U16 = Maxim, MAX6357LSUT
14)U19 = Texas Ins. TPS2211
15)U20= Philips, 74HCT138D
16)U21= Dallas DS1621
17)U22= Texas Ins PCI1510
18)U23= M-System MD-2810-008
19)U24= Philips, 74HCT139D
Message 14 of 20
(1,859 Views)
The Problem what we find sofar is that on SDCLK0 and SDCLK1 of the U3 is no CLOCK output
on the data sheet it says on page 114 you can programm then enable or disable so we think have to Program the U3 some how
Ifound the following tool http://www.fs2.com/pdfs/SNAV-GX.pdf
is that the right one and does NI have somthing like that.
Thanks again
                Rick
Message 15 of 20
(1,857 Views)
OK, I will have a look at it all.
What is the link with NI ?
Message 16 of 20
(1,851 Views)
Hi Rick,
The last link you posted is for an AMD proc. I don't know if it compatible with the NSC proc.
This means that you don't have a tool to verify that the BIOS prom (U1) is programmed correctly ?
Do you have a keyboard/monitor attached. Is there any output  ?
If not, for a start can you verify that the boot proces is started after a HW reset by measuring the #CE (pin 22) signal  MEMR# (pin 24) at U1
Message Edited by K C on 12-19-2007 11:54 AM
Message 17 of 20
(1,824 Views)
Hi KC.
Bios should be all right as we got one working Unit and we swapped the Bios Chip and works fine we tried all Program IC's all seem to work fine on the working unit.
We don't have a Display as it is normally just used as a satellite in a Network.
NS sold Geode to AMD so this link was from AMD for debugging and maybe programming the GX1?
As we think that there is a small program on the Processor GX1
We will try to swap the GX1 but waiting for the Reball station as it is a BGA
        Rick
Message 18 of 20
(1,818 Views)
Normally I would not start replacing components before you are sure that it is necessary. But when you are desperate.....................
If you don't have a monitor connected how do you observe that the board is working or not
What OS runs on the disk ?
Message 19 of 20
(1,815 Views)
Well I see the answer in the title   Smiley Happy
On a working board do you see the BIOS startup like you see with a 'normal' PC ?
Message 20 of 20
(1,799 Views)
