Multifunction DAQ
how to use virtual cards
Hi!
I work on a LabVIEW code which uses 5 cards NI (6503,6023,6023,6503,6704). I want to simulate these cards. So I created Ni daqmx simulated cards. when I launch  the labview program, I obtain the error -10401 when I try to use DIOconfig.vi. For information, I use the traditionnal daq driver 7.4.2.
 Is it possible to call virtual peripherals ?
Thanks.
(3,408 Views)
Traditional DAQ does not support simulation. You created them with DAQmx and that is what you must use.
(3,404 Views)
Accepted by satvrn5
Thanks for your reply! I have another question. I work with daq-mx. Is it possible to write digital ouptuts and then read them just using Labview?
 I work with LabVIEW 8.2. First I create a channel and start a task. Then I run a loop in which I write and read continuously the same port. But I never see this changing...
(3,367 Views)
