how to use virtual cards
Hi!
I work on a LabVIEW code which uses 5 cards NI (6503,6023,6023,6503,6704). I want to simulate these cards. So I created Ni daqmx simulated cards. when I launch  the labview program, I obtain the error -10401 when I try to use DIOconfig.vi. For information, I use the traditionnal daq driver 7.4.2.
 Is it possible to call virtual peripherals ?
Thanks.
(3,413 Views)
Traditional DAQ does not support simulation. You created them with DAQmx and that is what you must use.
(3,409 Views)
Accepted by topic author satvrn5
Thanks for your reply! I have another question. I work with daq-mx. Is it possible to write digital ouptuts and then read them just using Labview?
 I work with LabVIEW 8.2. First I create a channel and start a task. Then I run a loop in which I write and read continuously the same port. But I never see this changing...
(3,372 Views)
