hysteresis (bang-bang) control for thermostat in cDAQ
Hi Bing,
I was thinking of doing a similar project for my Degree in Mechatronics.
Could you send any info to me,as i was interested inhow your project turned out.
Do you need a motor to get a fan to work to turn on?
or is it better to use a heater to warm up the room?
Any info i would appricate it
Anthony
Message 11 of 18
(3,446 Views)
If you are close to a degree in mechatronics, you should be able to answer your questions by yourself...facepalm.gif
Greetings from Germany
Henrik
LV since v3.1
Message 12 of 18
(3,437 Views)
Hello Henrik, and all looking for a on/off temperature controller,
Here is a VI I created based off of Henrik's hysteresis-set point controller. I modified it so that the set point is the average of Ton and Toff, and so that the hysteresis is the difference between Ton and Toff divided by 2.
I am planning to read the temperature in from a thermocouple, and will output an on/off signal to a relay using the logic from the heater on/off.
I hope this helps any other people who are looking for this type of a controller.
Also, I would be interested to see Henrik's solution to this type of on/off controller (rather than hysteresis/set point).
Best,
Thomas
Message 13 of 18
(2,450 Views)
OMG that code is more than 8 years old.... I can't remember how many new PC's I got inbetween 😄
Maybe I find the time to look for that old vi... if I find that old harddrive ..
Q&D LV-Forum help vis rest on my local drive....
Henrik
LV since v3.1
Message 14 of 18
(2,437 Views)
I know this thread is a few months old but is there chance you can post your example in 2017 version?
Thank you in advance
Message 15 of 18
(2,053 Views)
made a picture ... the main control scheme is drawn in a minute ... this one is for cooling .. homework would be to change it to a heater 😄
Henrik
LV since v3.1
Message 16 of 18
(2,048 Views)
Good Morning Henrik,
Yes, your block diagram is easy to follow. I was referring to Thomas' Heaters Control.vi , Although I should be able to use your example, it would be nice to see what other ideas are out there. Thomas' vi is from a 2018 version, I'm using 2017. Even a screenshot would do.
Sandro
Message 17 of 18
(2,040 Views)
Good Morning
May I know why we have subtract the error with the hysteresis band and also what is the conversion done in the expression node why is it done
Message 18 of 18
(1,485 Views)
