Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
i'm attempting to output 2 channels from an AT-MIO-16E-4 board using
andy.mcleod@unh
.edu
Member
03-12-2008
01:00 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am simultaneously running 2 seperate VI's that call AO write vi which subsequently force an quit on both VI's. Is there a known issue here?
0
Kudos
Message
1
of 2
(2,804 Views)
Reply
Re: i'm attempting to output 2 channels from an AT-MIO-16E-4 board using
A_Ryan
Member
03-13-2008
03:01 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
andy.mcleod,
Depending upon the overall goal of your application, you can only have one hardware times AO Task running at time.
Simultaneous Analog Output Tasks on the Same Device
is a further expounds upon this idea.
NI-DAQmx: Multiple Analog Output Tasks Simultaneously
is an example that allows you to have multiple analog outputs.
I have some additional questions for you:
1. Can you please include a screenshot of the error?
2. Can you please include a screenshot of your code?
3. What hardware are you using?
A_Ryan
AES
Kudos
Message
2
of 2
(2,788 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
