i'm attempting to output 2 channels from an AT-MIO-16E-4 board using
I am simultaneously running 2 seperate VI's that call AO write vi which subsequently force an quit on both VI's. Is there a known issue here?
(2,836 Views)
andy.mcleod,
Depending upon the overall goal of your application, you can only have one hardware times AO Task running at time.  Simultaneous Analog Output Tasks on the Same Device is a further expounds upon this idea.
 NI-DAQmx: Multiple Analog Output Tasks Simultaneously is an example that allows you to have multiple analog outputs.
I have some additional questions for you:
1.  Can you please include a screenshot of the error?
2.  Can you please include a screenshot of your code?
3.  What hardware are you using?
A_Ryan
AES
(2,820 Views)
