interference on microphone daq usb
We are measuring small voltages from high quality microphones and have massive issues with interference. We have tested all equipment in a different building and there everything is working perfectly.
Now the issue may come from the building that we have to work in being surrounded by massive 10 m long steel plates, which of course are a magnetic interference source because they slightly move. The induced voltages can be up to 1 V peak peak
How can this be overcome? At the moment we are working with high quality shielded BNC cables and make them as short as feasible. Can a balanced wiring (how would that be done?) help? We cannot conduct the trial somewhere else.
Thank you in advance,
Michael
(2,199 Views)
There are DSA cards with mini XLR connectors which are better IMHO than the BNC version. What instrument are you using for measurement?
Santhosh
Soliton Technologies
(2,120 Views)
Type of Mic?
How is it mounted?
Spectra of the interference?
DI-Boxes ?
Greetings from Germany
Henrik
LV since v3.1
(2,097 Views)
