internal source for cDAQ 9174
Hi
I have 9174 cDAQ and in one of the slots I have a "current output" 9265. I need to power this 9265 with 12 V. One possibility is to power it with an external voltage source connected to pins 8 and 9. I am thinking (more for esthetics and less wires) if this can be powered directly to the 9174 which has a 12V DC source.
Any ideas ?
Thanks for help
Regards
(3,140 Views)
There is no "internal" source where you can have access to the +12V power supply of your cDAQ. You have to use an external power supply.
(3,114 Views)
