is daq card 6024e compatible with dasylab?
I am having trouble trying to get dasylab to recognise the daq 6024e card. I have downloaded nidaq 8.3.1 and it recognises the daqcard fine. Is this right? What driver to I have to download so that I can use the input in dasylab (8.00.04)? Sorry if this is an obvious question, I do not have much experience with the DAQ cards. Thanks
(3,318 Views)
Dear South,
Thanks for your request. Accordind with the forum "Does DASYLab support the USB DAQ devices", Dasylab works with the driver NI-DAQmx 7.5 and 8. For the version 8.00.04, you should also install the driver "NI-DAQ MX for DASYLab 8.00.04"
So, you must begin to uninstall the version 8.3.1 and install a previous version.
More informatons can ve found on
www.dasylab.com
Hardware Drivers Supported by DASYLab
Best regards
Nick_CH
(3,305 Views)
Thankyou for the help. I have done exactly this. installed a version of NIDaqmx 7.5 and the driver. Now there is a Nidaq drop down menu in dasy lab. However when I try to select an analog input, an error message comes up:
Driver: Task AD00, Version 0.08
Reason: No NI-DAQmx tasks available
Any ideas??
(3,285 Views)
Dear South,
Your welcome, I think you should first create a task in MAX and then use it in DasyLab. To learn more about NI-DAQmx and MAX, you can show this link:
Getting Started with NI-DAQmx: Measurement & Automation Explorer (MAX) Functionality Video (Creating a Task in NI-DAQmx and Using it in LabVIEW)
Best Regards
Nick_CH
(3,279 Views)
