CE.NET & USB-6008
Is it possible to make a solution which is developed in LabVIEW 8.2 enviroment but the target will be running on Windows CE machine and DAQ should be USB enabled NI-6008/9? If yes, what is the procedure to make it work (shortly softwares needed and steps).
Best Regards,
MV
(5,404 Views)
Hi MV!
Porting LabVIEW code onto Windows CE platform is possible through LabVIEW PDA Module for Pocket PC. However, there are a few requirements for HW running Windows CE OS, those requirements are discussed in the following tutorial, <http://zone.ni.com/devzone/cda/tut/p/id/4577 >. Available driver for USB-6008/9 and LabVIEW PDA is DAQmx Base version 2.1, <http://digital.ni.com/softlib.nsf/websearch/7C4B682FA842484F862571E60068FF3F?opendocument&node=132060_US >.
Best Regards,
JanH
(5,377 Views)
Thank you a lot.
BTW: Does anyone know could DAQmx support USB-6008/9 in Linux enviroment?
MV
(5,350 Views)
