is possible to use ni usb 6353 carte with Matlab 2010a
Bonjour
On a acheté une carte NIUSB 6353, mais dans mon ordi j'i la version 2010a de Matlab. Est ce qu'il y a un moyen de contrôler cette carte avec cette version de Matlab
Merci d'avance
(3,205 Views)
Accepted by topic author Miguel_Suarez
And thank you for posting here.
Please write in english if you post here. Otherwise, post on the french forum.
The NI USB-6353 using the DAQmx driver, it should used with Matlab.
Please find several links relative to the NI USB-6353 by clicking here.
Jérémy C.
NI France
(3,198 Views)
Thank you for reply
I used the Daqmx Tools, it works very well. But I wanted use de daq toolbox for contrôler the usb carte, and have access to carte parameters.
Finaly, I going work with Labview for controler the carte
Best regards
(3,193 Views)
