Multifunction DAQ
kistler 8640A and NI 9234
I have probably a very simple question.
Is it possible to conduct the Kistler PiezoBeam accelerometer 8640A5 http://www.kistler.com/mediaaccess/8640A_BP__000-842d-03.11.pdf
at the NI 9234.
If not what hardware would you use to operate max. 16 8640A5?
Thank you!
(4,207 Views)
hello,
here in addition the english data sheet of the Kistler 8640A http://www.kistler.com/mediaaccess/8640A_BP__000-842a-03.11.pdf
(4,200 Views)
Accepted by StefanErgenz
You can and would also be able to use TEDS
https://www.ni.com/en-us/shop/model/ni-9234.html
(4,196 Views)
Hi Stefan,
echelon 101 has mentioned that youo can find the following  information in the data sheet: (-> Unbenannt.png)
You only need to configure the device (TEDS in 9234) in Measurement & Automation Explorer (MAX):
Kind Regards,
Philipp K.
AE | NI Germany
(4,186 Views)
