laptop interface to BNC-2120 device
We have four data acquisition modules model number BNC-2120.  This is a desktop or DIN rail mountable accessory that connects to E series, Sseries and waveform generation Multifunction DAQ device.  Question is is there a 68 pin I/O connector with laptop interface available?  Thanks.
(2,908 Views)
A BNC-2120 is not a data acquisition device. The data acquisition device is an M-Series, E-Series, S-Series board. You connect the BNC-2120 to the data acquisition device and the data acquisition device is connected to the pc. If you are looking for a data acquisition device that you can use with a laptop, then you can start here. You did not provide any information on the type of data acquisition you need so if you want a recomendation, you need to provide that. You can also contact your local NI Sales Engineer.
(2,903 Views)
