From the error code, it sounds as if at some point in the task it is losing the channels to acquire from.
As for the incorrect readings, do you see the same thing from a test panel in MAX? If you are getting incorrect readings in MAX, it's possible that the device is malfunctioning.
Please reply with your results.
Sean C.
Applications Engineer
