lv 8.6 installer not working for daqmx
I am trying to build an application and installer.  This program will run as an executable on a separate, non-LV machine.  When I build the installer (I include the LV RTE, DAQMX & MAX installers also), I get a nice error message after it tries to load the distributions from the dvd: (If you have any insight I'd love to hear it)
Build was unsuccessful.
CDK_Item_OnDoProperties.vi.ProxyCaller >> CDK_Item_OnDoProperties.vi >> CDK_InstallerConfiguration_Editor.vi >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_Build.vi >> NI_MDF.lvlib:MDFDistCopyList_VerifyItemPresent.vi
Loading product deployment information
Adding files to installer
Done adding files
Preparing to build deployment
Copying products from distributions
*** Error: Improper function call or command line argument. (Error code -30)
*** End Error Report
 Copying distribution 'LabVIEW 8.6, Disk 1' from: D:\Distributions\LabVIEW 8.6\LabVIEW860\ to: C:\Aerel\Customers\Composite Solutions\DAQ\Builds\THT ManualTesting\HydroTest Installer\
Error verifying distribution present: National Instruments Device Drivers - August 2008, Disk 1
Done building deployment
(2,747 Views)
Hi Havelld,
Can you post your VI so that we can try to create an installer and see if we reproduce your error?
Ipshita C.
(2,732 Views)
