09-16-2008 03:49 PM
I am trying to build an application and installer. This program will run as an executable on a separate, non-LV machine. When I build the installer (I include the LV RTE, DAQMX & MAX installers also), I get a nice error message after it tries to load the distributions from the dvd: (If you have any insight I'd love to hear it)
Build was unsuccessful.
CDK_Item_OnDoProperties.vi.ProxyCaller >> CDK_Item_OnDoProperties.vi >> CDK_InstallerConfiguration_Editor.vi >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_Build.vi >> NI_MDF.lvlib:MDFDistCopyList_VerifyItemPresent.vi
Loading product deployment information
Adding files to installer
Done adding files
Preparing to build deployment
Copying products from distributions
*** Error: Improper function call or command line argument. (Error code -30)
*** End Error Report
Copying distribution 'LabVIEW 8.6, Disk 1' from: D:\Distributions\LabVIEW 8.6\LabVIEW860\ to: C:\Aerel\Customers\Composite Solutions\DAQ\Builds\THT ManualTesting\HydroTest Installer\
Error verifying distribution present: National Instruments Device Drivers - August 2008, Disk 1
Done building deployment
09-17-2008 06:24 PM
Hi Havelld,
Can you post your VI so that we can try to create an installer and see if we reproduce your error?
Ipshita C.
