measure time transistion between two analogue waveform
How to measure the time transition between two analogue waveform?
(3,015 Views)
Hi *LJ,
It sounds like you might want to know how to measure the phase delay of two signals. One way it can be done is to use the Extract Single Tone Information VI to get the phases of the two signals and compare them. I’ve taken an example from our Example Finder and added the mentioned VI to the output of the DAQmx Read. I’ve included the VI I modified so you can see what I’m talking about.
If this is not what you want, please tell a little more about your application so everyone reading the forums can more fully understand what you’re trying to do. “Time transition” could mean several different things, including the delay in sampling waveforms on different input channels, or other in-depth situations.
I hope this helps.
Mark E.
Precision DC Product Support Engineer
(3,001 Views)
