measurement and automation usb recognize
Spoke too soon.  I rebooted and now it's not working again.  Simulated devices don't work and my DAQ is not recognized even when MAX is run as administrator.
Message 11 of 33
(2,178 Views)
What type of antivirus software are you using?  It's possible that it's deciding to quarantine something that NI-DAQmx and MAX needs.  Can you confirm that you have a C:\Program Files\National Instruments\MAX\Data Dictionaries and can you create a Technical Report in MAX?  To create the report, go to File » Create Report and select "Technical Report".
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 12 of 33
(2,174 Views)
I was able to create a technical report in MAX.  I'm using Microsoft Security Essentials and Comodo firewall/anti-malware.  Neither of these show any quarantine or blocking of anything obviously NI related.
The first time I had rebuilt the driver database according to the instructions in the previous post, it was able to recognize the DAQ.  I went through several reboot cycles to make sure this was reliable, and after about 5 reboots it stopped recognizing the DAQ.  The windows device manager previously showed the DAQ under Data Acquisition Devices, but now shows USB Firmware Loader instead.
I don't know where else to go with this.
Thanks for helping me with this problem, by the way.
Message 13 of 33
(2,170 Views)
Could you type "services.msc" into the search box in the Windows Start Menu and hit Enter.  When the Services window comes up, check the status of the NI Device Loader service, and if it isn't started, try to start it.
Seth B.
Message 14 of 33
(2,167 Views)
The service was not running and the Startup Type was set to Automatic.  I started it and plugged in the DAQ but it still isn't being seen.  I also rebooted the computer and started the service again, but still nothing.
Message 15 of 33
(2,162 Views)
I just noticed that the NI Device Loader service stops immediately after I start it.  It won't stay on.  Is that normal?
Message 16 of 33
(2,157 Views)
Let's see if the Windows Event View has any information we can use to determine why this service is stopping.  In the search box in the Windows Start Menu, please enter "eventvwr.msc" and hit Enter.  In the Overview & Summary box, look in the Summary of Administrative Events to see if there are any errors or warnings related to NI Device Monitor.
Seth B.
Message 17 of 33
(2,120 Views)
There were no errors or warnings directly related to the device loader or monitor.  There were several errors with the NI Variable Engine and nipalu.  The Variable Engine seemed to have 3 recurring errors:
NI Variable Engine:
ni_tagger_plugin_mxs.dll: Failure to load plugin: Unexpected Error: Unable to get the Interface from the plug-in.
Unable to load the MXS configuration plugIn: Failed to get MAX Configuration interface for Tagger: 0x80040318
Failed to initialize PSP XT Server
nipalu:  there are several errors including this one...
[nidevldu] [[nidevldu]] Fatal: p:\Measurements\Infrastructure\devld\trunk\1.12\source\nidevld\tDeviceLoader.cpp:271 - Could not connect to MXS. MAX configuration files may be corrupt!
I noticed that there is a recurring error with the Service Control Manager related to the NI Device Loader.  "The NI Device Loader service terminated unexpectedly. "
Message 18 of 33
(2,111 Views)
Could you attach the Technical Report you created earlier?
Also, could you look in the Control Panel » User Accounts » Manage User Accounts window to see what group your user account is in?
Seth B.
Message 19 of 33
(2,108 Views)
My account is an Administrator account.  I've attached the MAX report.
Message 20 of 33
(2,081 Views)
