Multifunction DAQ
measuring resistance but value is not constant
I used two known resistances to check, if my programme is right. Resistances are 400 Ohms. I made shema, which I drew (Only I replace 9 pin to 10 pin). I wrote the programme which generate 10 voltage in output and  reads voltage in all channels. My question is - why voltage in 10 pin is about 0? I added printscreen.
I'm waiting for answer.  🙂
Message 11 of 12
(1,057 Views)
Accepted by Zancis
Because it is tied to the AI GND.  It should be at 0V.
Message 12 of 12
(1,043 Views)
