microphone ni 9233
Hi. I need to buy microphone to NI 9233. Can you reccomend good microphone? Thank you.
(3,060 Views)
Hello DaPuCZ,
Take a look at this KnowlegeBase article.  It has some good information on how to choose one as well as links to a couple common vendors:  How to Choose a Microphone for Sound Measurements
Have a great day!
Cheers,
Brooks
(3,031 Views)
Hi DaPuCZ,
What signal are you primarily interested in measuring? This will affect the microphone type (free field, pressure field, random incidence), microphone size (based on frequency response and dynamic range), and preamplifier. For ease of use with the NI-9233, you will probably want a prepolarized microphone to make use of the IEPE signal conditioning from the NI-9233 and a preamplifier with a BNC output.
I would also recommend looking at some additional resources such as this guide from G.R.A.S. Sound and Vibration and this guide provided by PCB Piezotronics. Here is a list of some additional vendors where can get your microphone. Let me know if this helps.
Kent
(3,022 Views)
