microphone sensor sensitivity calibration
I am using a Bruel & Kjaer 4189 microphone and 2671 pre-amp and acquiring data using NI-USB 9233 DAQ device, Labview 8.0, DAQ 8.0.1 on windows 2000.
I performed mic calibration using the SVT toolkit and adjusted my DAQ sensor sensitivity in my program accordingly, to 46.2. My data acquisition was going well but bizzarly after a few days the audio suddenly started to sound exteremely sensitive. When I recalibrated I got roughly the same value as before. However when I set the sensor sensitivity to about 150, the audio sounded normal again.
I have tried this on a few different mics, new and old.
Any suggestions to what the problem might be would be much appreciated.
(3,325 Views)
With regards to the sensitivity values you have been previously using; if the sensitivity level is set fairly low it will pick up very slight variations in sound which includes noise. So you may end up amplifying a lot more noise. With a higher sensitivity level less noise would be amplified and if you want to record louder noises you will probably get a cleaner signal with a higher sensitivity setting. So even though the calibration says you can have a sensitivity of 46 you may want to keep it around 200+ just to prevent any extra noise. One other thing to double check is whether the calibration signal is being clipped which could cause inaccuracies in the data.
I would just use a value thats sounds good for you and that fits your application.
(3,284 Views)
