Multifunction DAQ
missing dll
When installing NI-DAQmx 9.0.1, I get an error.  In the upper left corner on the dialog it indicates that the error is with "nidevmon.exe - System Error".  The error description is: "The program can't start because nimhwcfu.dll is missing from your computer.  Try reinstalling the program to fix this problem."  I have reinstalled the program, and I have uninstalled and then reinstalled the program.  Still the same error.  The computer is new, and the OS is Windoze 7.  I looked for the dll, and it is indeed not present in the system32 folder, which is where I found it on my desktop PC. This error happens during the installation process.
Jim
LV 2020
(5,698 Views)
Accepted by lmtis
9.0.1 is not supported on windows 7. Try the latest.
(5,686 Views)
Odd, the disk is labeled as Win 7 compatible.  Whatever, it appears that you are correct.  Installed 9.2.1 and all is well.  Thanks Dennis.
Jim
LV 2020
(5,632 Views)
